3 members (Guitplayer, JW51, 1 invisible), 67 guests, and 2 robots.
Topics128,050
Posts1,055,757
#964720 08/18/2013 3:03 PM
I want to remove my rear fenders to clean and under-coat them and have better access to the side of my frame to clean and paint. I also want to add fender welt, (debatable necessity in StoveBolt, but the original front fenders on my tuck have the welt).
Unfortunately the PO seems to have welded the fender to the side bed panel and I don't know how to carefully cut the weld and dismantle the fender and bed-side. Photo below.
Welded rear fender (close up near the bottom at rear)
Is there a tool that can carefully grind or cut this out and not abuse the adjacent paint? Any thoughts?
Bob
1954 Chevy 3100 5-Window
1954 5-Window COE aka "THE BEAST"
Bill Ritchie's Original Truck
Granddad's Hardware Store: Ritchie Hardware, Concord, N.C.
Bethesda, MD
Ritchie 54 #964727 08/18/2013 3:15 PM
Dremel tool may be your best bet. They also sell very thin cut-off discs for straight/angle air grinders.
Ritchie 54 #964730 08/18/2013 3:19 PM
hard to tell from that pic, a zip wheel on a die grinder might get it off, but it's highly unlikely you'll cut a welded fender loose without messing up the paint, including on the other side of the metal [inside the box] .... if the fenders look OK as-is, I'd be more inclined to remove the bed, with fenders, and flip it up to do the work you want, much less hassle and refinishing - and welting on the front doesn't mean there was welting on the back
Ritchie 54 #964754 08/18/2013 4:37 PM
Never thought of removing the entire bed. Novel idea; now I just have to devise a hoist / pulleys from my ceiling since it is not that heavy.
I might tinker in an inconspicuous place first with a Dremel tool.
Bob
Bethesda, MD
Ritchie 54 #964769 08/18/2013 5:06 PM
Good luck with getting the rear fenders off. Do it slowly and carefully.
Originally, there was no A-D rear fender welt, except on panel-body trucks. Some people put a strip of 30# roofing felt between the fender and the bedsides.
Ritchie 54 #964772 08/18/2013 5:10 PM
a Dremel tool would run thru thousands of those tiny cutting discs to get one fender off - if the tool [or you] didn't burn out first wink
Ritchie 54 #964793 08/18/2013 5:50 PM
The weld is only 1-1/2" long. I'm going to buy a stack of the Dremel cut-off blades and hope I don't get myself in too much trouble. Thanks to all!
Bob
Bethesda, MD
Ritchie 54 #964827 08/18/2013 7:53 PM
back yard wrench turner
If you have an angle grinder, a diamond tile cutting blade or a metal cutoff wheel will zip through it very quickly.
The dremel is for really small stuff, you won't make much headway with it.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Ritchie 54 #965017 08/19/2013 11:01 AM
My 13 year old son and I moved the bed on my '53 GMC and I removed a long wheel base bed ('58) by myself the other day by lifting the rear of the bed alone and slipping a 8 foot 2x4 under it and pushing it the rest of the way off. Both of these beds had no wood left in the floor. They are cumbersome, but not too bad heavy. A couple of grown men could wrestle one off easy, it was tough with my 13 year old when we got to lifting it over the wheels, he struggled hard.
Ritchie 54 #965248 08/20/2013 2:57 AM
lefty1: 13 year old will remember that day for a long time and remember it well. Nice!
Steve H
Ritchie 54 #966644 08/24/2013 6:27 PM
Dremel tool with metal cut-off wheel worked great. It cut a very clean slot in the weld and only used a couple of the blades. I should have the fender off tomorrow.
Bob
Bethesda, MD
Ritchie 54 #966647 08/24/2013 6:30 PM
Good work, Bob
I'm surprised! I've never had any luck with using a dremel. Glad it worked for you. smile
Wayne
1989 Silverado
Ritchie 54 #966695 08/24/2013 9:45 PM
I would use a 3" cutoff wheel on edge. I find I can get really good control with those. That is how I grind sheet metal welds.
1951 1 Ton Completed
Ritchie 54 #966747 08/25/2013 8:30 AM
Dremel makes a 1-1/2" and even a 2" metal cutting blade, I think. Their new EZ Lock mandrel makes a big difference in holding the blade secure while cutting and taking the blades off and on. The cut ended up being the width of the blade - maybe 3/16". Very clean, controlled cuts.
Bob
Bethesda, MD
Ritchie 54 #966748 08/25/2013 8:46 AM
I have extensively used two Dremel tools (corded and cordless), when I needed very thin cuts in metal. One tol locked up on after cutting off about 50 bolts/nuts under a Suburban floor. $15 got a Dremel rebuilt/replacement unit. It was worth every penny of the cost.
Ritchie 54 #966920 08/25/2013 9:21 PM
Gas Pumper
Gas Pumper
I have a dremel I have had since before the crusades, so the cutoff wheels last as long as it takes to install them. One of these days I am gonna invest in a new model and accessories.
I haven't addressed this properly because so far the 3 inch air die grinder or the 4 inch Makita electric have worked okay. When getting in to close areas, an air body saw finishes. Still I hear good things about the newer Dremel.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Deve #966945 08/25/2013 10:12 PM
Deve, this is my issue also!
Wayne
1989 Silverado
Ritchie 54 #968503 09/01/2013 8:35 PM
There is a "Z" shaped reinforcement on the inside of my rear fenders abutting the running board. My fender is pretty trashed but good enough shape to stay on the truck a long time, now that I have cleaned it up, de-rusted and applied some undercoating. Does anyone know if this "Z" shape is something added by a PO or a factory reinforcement? Seems like something I could have a sheet metal shop make or maybe there is a re-pop made for this part.
Inner fender reinforcement
Not the best photo but it would be shaped the same as the running board to fender gaskets
Runnning board to fender gasket
Bob
Bethesda, MD
Ritchie 54 #981889 10/28/2013 2:24 AM
So I got my fender off (took a few Dremel blades) and have it all painted and under-coated inside; ready to re-install. I found rubber washers at Home Depot and wonder if anyone has used rubber washers to re-assemble the body parts. Kind of makes sense to put a large rubber washer (about 1/8" thick) between the fender and the bed side. It would eliminate the wear and tear that eventually happens with metal on metal. I guess this is why they sometimes put in fender welt, but this seems like a good alternative. Any thoughts?
Bob
Bethesda, MD
Ritchie 54 #981893 10/28/2013 2:32 AM
Gas Pumper
Gas Pumper
It sounds okay, but then you are leaving a gap for water to coalesce and cause potential problems. The fender welt was uniform and keeps water out of everything. Not sure if fender welt is overly expensive. Originally there was nothing, but once you work on these awhile you wish they would have done that because of the rust problems that were created.
Deve
The Think Tank
Ritchie 54 #981901 10/28/2013 2:43 AM
I guess the rust is what I am reacting to. The bed sides are more rusted than I want to admit and the rubber washers minimize the metal to metal and further deterioration. i don't think I am creating more of a water issue, arguably adding a small 3/32" space (after the washer is compressed) might allow water to freely drain and not collect in the metal parts. The fender welt is probably the least expensive part on the truck - maybe I should just stick with that.
Bob
Bethesda, MD
Ritchie 54 #982047 10/28/2013 8:16 PM
Go with fender welt if you want something in there. Having a 3/32" space will still collect water, due to surface tension and capillary action. It's best to have something that keeps moisture from getting in or nothing at all, rather than a small gap.
I like your rubber washer idea for other areas. Not between the panels, but under the regular washers and things like that to prevent squeaking. I'm going to steal that thought.
My 46 GMC on Photobucket
