8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd), 97 guests, and 1 robot.
Topics128,049
Posts1,055,702
#979188 10/17/2013 1:30 AM
Does anyone know the procedure for installing hinges that work to the inside instead of outside? I have seen this on a few mods.
My goal is to end up with rear lift gate and smaller barn doors (minis).
cheers
you can use a hidden hinge kit for a 34 chevy.
Greetings;
Thanks got a hold of Hidden Hinges and they quoted $425. a set.
And to go thru Yogi's. Very expensive. Shall look at other avenues.
I know someone that used 1951 car hinges to swing open a clam shell door. Itlooked perfect and opened well. Look at later year suburbans and see how rthey mount. Look at modern delivery vans ,I know some of them have concealed hinges too. .....g
