1 members (1 invisible),
65
0
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Does anyone know the procedure for installing hinges that work to the inside instead of outside? I have seen this on a few mods. My goal is to end up with rear lift gate and smaller barn doors (minis). cheers | | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | you can use a hidden hinge kit for a 34 chevy. | | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Greetings; Thanks got a hold of Hidden Hinges and they quoted $425. a set. And to go thru Yogi's. Very expensive. Shall look at other avenues. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I know someone that used 1951 car hinges to swing open a clam shell door. Itlooked perfect and opened well. Look at later year suburbans and see how rthey mount. Look at modern delivery vans ,I know some of them have concealed hinges too. .....g | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | | | |
