2 members (sron48, Gray_Ghost),
105
Mod | | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | John,
I have replaced all of the wood work on my 41, but I did it when the cab was off of the frame. You could remove/replace that piece with the cab on, but it would be difficult as the wood is sandwiched between the cab and the 2 cab channel iron pieces which bolt to the frame. You may try unbolting the front body mount, removing the ~6 bolts attaching the cab to the channel iron (all the way to the back of the cab), and then carefully prying to separate the cab and channel apart. Don't pry too hard or too high though as there is not much structural integrity between the cab and the firewall when you have it this far apart. Crazy prying/lifting could distort your windshield A-pillar which would affect your windshield alignment.
Make sure to use a decay resistant wood for a replacement as you will not want to do this twice.
Paul | | | | | Joined: Dec 2007 Posts: 26 New Guy | | New Guy Joined: Dec 2007 Posts: 26 | thanks Paul,, I didnt think it would be easy, but at least its doable,,, | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Yes, it is not easy but can be done. Good luck! | | |
