0 members (), 38 guests, and 4 robots.
Topics128,089
Posts1,056,004
Members48,430
Has anyone replaced the toe wood blocks on the lower cab? Does the job require raising the cab or can it be done without that? Are there any spot welds that need to be separated? Thanks,, Here is the area I am referring too:
http://i945.photobucket.com/albums/ad294/TheNovadude/DSCN1354_zps08a1a67d.jpg
1942 Chevy Firetruck project 1 1/2-Ton
More pix and video
1941 Chevy 1/2-Ton -- Now gone
More pix on Photobucket
John,
I have replaced all of the wood work on my 41, but I did it when the cab was off of the frame. You could remove/replace that piece with the cab on, but it would be difficult as the wood is sandwiched between the cab and the 2 cab channel iron pieces which bolt to the frame. You may try unbolting the front body mount, removing the ~6 bolts attaching the cab to the channel iron (all the way to the back of the cab), and then carefully prying to separate the cab and channel apart. Don't pry too hard or too high though as there is not much structural integrity between the cab and the firewall when you have it this far apart. Crazy prying/lifting could distort your windshield A-pillar which would affect your windshield alignment.
Make sure to use a decay resistant wood for a replacement as you will not want to do this twice.
Paul
Lots more pictures
thanks Paul,, I didnt think it would be easy, but at least its doable,,,
More pix and video
Yes, it is not easy but can be done. Good luck!
Lots more pictures
