0 members (), 188 guests, and 3 robots.
Topics128,089
Posts1,056,441
Members48,443
#981801 10/27/2013 7:59 PM
I
I Offline
The fuel pump on my 6 cyl 270ci gmc motor is spittin' fuel out of a small hole located in the base of the pump, down where the mounting bolts are. It's a factory hole, diameter is about the size of the lead in a pencil. Not sure why it's there, no idea why it would be spittin' out fuel when it's running- any ideas?
53 Chevy 210 convertible; 55 GMC pickup; 57 GMC Suburban Carryall
Ex Hall Monitor
Ex Hall Monitor
Likely a small split in the diaphragm. Replace it before it leaves you stranded.
I
I Offline
Thanks Tiny, will do!
Just to clarify - that hole is there to tell you your pump is leaking. It's a telltale weep hole. All mechanical fuel pumps have one.
1950 4100 - unrestored and driven weekly for almost no reason at all.
Make sure you check your engine oil for fuel smell. If any doubt, change it and the filter.
I
I Offline
Thanks to all, definately learned something today!
I let my carb sit with Ethanol and had issues after. If you drive your vehicle daily "im told" you won't have issues but if it sits you may consider using ethanol free fuel.
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
Umm... if its a mechanical fuel pump there is no need to vent it.. the base (with the arm) is open to the interior of the block, which IS open to atmosphere (via the PCV or simple draft tube).
Also, the location of this weep hole is not at the lowest point or any point where fuel would readily pool to indicate a problem.
Is there anything in a shop manual about this hole????? Just curious.
