| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I installed an electric wiper conversion on my "48" 1/2 ton a few months ago and drove it for some time without the wiper blades installed. When I finally got around to installing them I found the stop point has the blades in the up position. They operate perfect but stop in the up position. Is there an adjustment to change this. I would think it needs the electric switch to open in a different location but not sure if this can be change. As I recall I got the motor from Jim Carter.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I purchased a wiper conversion from Newport
Had to adjust the park on it On the Newport there is a socket head cap screw that you loosen and reposition to adjust. The screw is on the hub under the arm that the two transmission arms connect to.
I'm surprised that your transmission arms don't bind when they sweep if your park is midway.
| | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | Nothing binds on these. The wipers actuate just right. In my mind I am thinking in need to adjust when the contact opens to kill power. If my park is up and the first action takes the blades down I would think adjusting the hub so the blades are parked down will just bind the arms since the action is trying to go down more. I need a call for the wipers to start in an upward motion, opposite of what mine are doing now. I checked, this is a Newport motor. I will have to crawl under the dash and look.
| | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | When I did this install recently, I had the same issue. If you swap the arms at the motor, top for bottom, that should fix your problem. Undo both e-clips, put the bottom arm on top and the arm on top, on the bottom post. Re install the e-clips. There might be some tweaking involved. | | |
