7 members (TexasJim50, rick46ia, cmayna, Southerntruck, SNOYL, ShopRag, Mike Roache),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,006 Posts1,055,271 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | I'm not a body man, I can only work in approx. 2 hour time frames. I have 7 in and 41/2 in grinders and misc sanding blocks and drill discs. What specific disc (grit) and/ or tools should I get to remove paint from cab the quickest? What specific primer should be applied to the clean metal? Haven't decided wether to use urethane or acrylic enamel paint which requires different prep. Sandblasting is not an option except for small pieces. Thanks in advance for for input! | | | | | Joined: Jul 2013 Posts: 224 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 224 | I used a razor blade to remove the paint ....
" STUCK IN THE '50'S "
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Thanks, I've found a lot of info in the search area. No other suggestions needed at this time. Should have looked there first. | | | | | Joined: Nov 2008 Posts: 544 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 544 | YouTube has a few guys who go through the whole process. I like this guy...the videos are concise, to the point, and make sense, with pretty good audio and video. http://www.youtube.com/channel/UCqCRBowSBc3OVvptRY10ZJwjamesfreddys if the link doesn't work. | | |
