Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (cmayna, jay d, 2-Ton, 2 invisible), 44 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#979781 10/19/2013 5:58 PM
I'm not a body man, I can only work in approx. 2 hour time frames. I have 7 in and 41/2 in grinders and misc sanding blocks and drill discs.
What specific disc (grit) and/ or tools should I get to remove paint from cab the quickest? What specific primer should be applied to the clean metal? Haven't decided wether to use urethane or acrylic enamel paint which requires different prep. Sandblasting is not an option except for small pieces.
Thanks in advance for for input!
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Duwop #979840 10/20/2013 12:44 AM
I used a razor blade to remove the paint ....
" STUCK IN THE '50'S "
Duwop #979852 10/20/2013 1:13 AM
Thanks, I've found a lot of info in the search area. No other suggestions needed at this time. Should have looked there first.
More pix on Flickr
Duwop #981090 10/24/2013 6:36 PM
YouTube has a few guys who go through the whole process. I like this guy...the videos are concise, to the point, and make sense, with pretty good audio and video.
http://www.youtube.com/channel/UCqCRBowSBc3OVvptRY10ZJw
jamesfreddys if the link doesn't work.
