7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl),
117
Mod | | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | Are running boards from a 1-1/2 ton the same as 3/4 ton factory flatbed? (short) Want to bolt 1-1/2 ton running boards to 3/4 ton fenders. (else I'll have to buy different running boards). These are for a 1946 Chevy 3/4 ton.
Grease magnet
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I think you'll find the 1.5 ton chassis use a shorter running board that only extends to the rear of the cab. That leaves the spece between the back of the cab and the front of the rear fenders open. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've never seen rear fenders on a flatbed. I would expect the 1 1/2-2 ton boards to work on a 3/4 ton flat bed. But I have no idea how 3/4 ton factory flatbed boards were mounted. | | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | Thanks, I was worried about the width of the running board where the fender attaches. They mount on brackets extending from the frame.
Grease magnet
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I forgot about the difference of the front fenders. May fit, may not. | | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | Someone said that the only differences between 1-1/2 ton fenders and 1/2 ton fenders are the 1-1/2 ton fenders are cut out at the front edges to prevent the larger tires from rubbing when turning. I haven't been able to verify this.
Grease magnet
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check the resto pack, page 57 and others, there's more difference than just those front cuts, the big truck fenders are bigger Bill | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | I have a 51 3600 3/4 ton and had trouble with running boards. Mine were torn up badly and I tried to find aftermarket running boards for the 3/4 ton. I never did find any and had to rework the old ones. It took a while but I was able to reuse them. The running boards seem to be like rear 3600 brake drums, impossible to find! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like you only choice on reproduction 3/4 ton running boards is fiberglass. Same material that is used for repo rear valance (deflector) on 47-55 panel body trucks.
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If I'm not mistaken, the 1.5 ton running boards hang lower. | | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | They may hang lower. I need to compare the running board supports, or at least find the specs for both.
Grease magnet
| | | | | Joined: Jun 2012 Posts: 7 New Guy | | New Guy Joined: Jun 2012 Posts: 7 | Where do you get the fiberglass ones?
1949 Chevy 3600
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Any vendor that carries parts for these trucks, like Jim Carter, for sure.
