4 members (Otto Skorzeny, Johnny Rib, dwreills, 1 invisible), 95 guests, and 3 robots.
Topics128,036
Posts1,055,461
Members48,422
#98099 11/14/2006 3:43 AM
What should the voltage read at the fuel sending unit. I got 5 volts when I thought it should be the same as the battery v. Is there supposed to be resistance somewhere in the circut?
trial and error all over again.
#98100 11/14/2006 5:45 AM
The sending unit itself is nothing but a variable resistor . The meter movement also has resistance. There is ground on the other side of the sending unit and twelve volts on the other side of the gauge, so you effectively have a voltage divider. The voltage will change with the fuel level. The voltage on the sending unit side of the gauge will be twelve volts if you disconnect the sending unit wire.
#98101 11/14/2006 3:10 PM
Thank you Baldy,
That is a good thing to know. Does that mean that if the voltage changes with the amt. of gas in the tank that the sending unit is working?
#98102 11/14/2006 4:55 PM
Ex Hall Monitor
Ex Hall Monitor
Your gauge measures resistance. Your sending unit provides that resistance. Full position is 30 ohms resistance, empty is about 1-2 ohms. That is what you need to check. Measuring voltage will not tell you much.
#98103 11/14/2006 7:33 PM
Thats nice and all but could some body tell me why the gas dosn't exploded with an electrical devise like a sending unit or fuel pump is put in the tank. Can you spell boom? I have never seen or heard of one exploding.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#98104 11/14/2006 7:57 PM
No spark, no boom. Plus, gasoline by itself isn't explosive, just the vapor.
Of course, light it on fire and you'll see it evaporate quickly enough to cause problems. grin
#98105 11/14/2006 8:24 PM
Ex Hall Monitor
Ex Hall Monitor
Brendan is right plus I've read that the ratio of oxygen to fuel capable of producing an explosion is pretty precise. Too much fuel for the available oxygen and it won't burn. I watched a show on TLC a while back where they were trying to set spewing natural gas on fire using flare guns. They had to hit just the right spot or the burning flare would go right through the spouting fuel and not light it off. There would be a ton of vapor in the gas tank but little oxygen.
#98106 11/14/2006 9:24 PM
Toyvo
If your gas tank blew up it would be a terrible accident ! smile
Stuart
#98107 11/14/2006 9:36 PM
But in the movies a bullet can explode a gas tank. And somehow or another those little car gas tanks always have 100 gallons of gasoline in them when they explode. eek
#98108 11/14/2006 10:05 PM
Stuart
It certainly would and much worse if you have a cab mounted tank -- like mine. smile
#98109 11/14/2006 10:10 PM
Quote
Originally posted by redtruck65MA:
Stuart
That reminds me. I get a strong smell of gas every time I get in the truck. The tank and filler hose are good-- no leaks so where does it come from?
#98110 11/15/2006 1:11 AM
Ex Hall Monitor
Ex Hall Monitor
Probably the sending unit gasket.
#98111 11/15/2006 11:58 PM
I'm retired every day -- many times a day. It's good to have the time to appreciate life and rest when you have to.
