8 members (Peggy M, klhansen, Charles in CA, Hush, Nick in Manitou, 41 chev, Bucker, 1 invisible),
179
Mod | | | Forums66 Topics128,270 Posts1,058,408 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I've had some trouble keeping manifold gaskets on my '46 235. I finally bought a good set of Fel-Pro gaskets and followed their detailed instructions. The truck has run very well until yesterday. I recognized the sputtering and lack of idling. When I got home, I took a wrench to it and was able to turn a little bit on all but one bolt on the donut gasket. Some moved very little, others got at least a quarter turn.
My question is: should I be putting Loc-tite or some similar product on the bolts to keep them from loosening? I've driven the truck a couple of hundred miles since putting the gaskets in. I do occasionally drive on the main road through town and open her up to 50 MPH, but usually stick to the side roads and keep it under 45. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Manifold gaskets seat in with a few heat cool cycles and will need to be re-tightened. You should not need Loc-tite.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Is there noticeable slop in the bolts/head? New bolts may be in order. I don't now if Loc-tite will hold up to the exhaust heat.
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I'll keep an eye on it. Just wondering if this was normal. Thanks. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | Loctite, no. Never-seez yes. | | |
