3 members (WICruiser, 2 invisible), 142 guests, and 4 robots.
Topics128,109
Posts1,056,269
Members48,439
#980876 10/24/2013 12:55 AM
I've had some trouble keeping manifold gaskets on my '46 235. I finally bought a good set of Fel-Pro gaskets and followed their detailed instructions. The truck has run very well until yesterday. I recognized the sputtering and lack of idling. When I got home, I took a wrench to it and was able to turn a little bit on all but one bolt on the donut gasket. Some moved very little, others got at least a quarter turn.
My question is: should I be putting Loc-tite or some similar product on the bolts to keep them from loosening? I've driven the truck a couple of hundred miles since putting the gaskets in. I do occasionally drive on the main road through town and open her up to 50 MPH, but usually stick to the side roads and keep it under 45.
Manifold gaskets seat in with a few heat cool cycles and will need to be re-tightened. You should not need Loc-tite.
My Blog
Is there noticeable slop in the bolts/head? New bolts may be in order. I don't now if Loc-tite will hold up to the exhaust heat.
I'll keep an eye on it. Just wondering if this was normal. Thanks.
Loctite, no. Never-seez yes.
