| | | Forums66 Topics128,100 Posts1,056,170 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 110 | I was able to find an overdrive transmission out of a `55 210 for my `59 1/2 ton pick up. Got the stock rebuilt 235 and the trans dropped back into the frame today. My linkage arms from my column shift 3 speed don't seem right. What is the right set-up for me?
1959 Shortbed stepside 1/2 ton project ![[Linked Image from i236.photobucket.com]](http://i236.photobucket.com/albums/ff117/olddaze/Chevy%20truck%20project/photobucket-4342-1325944221019.jpg) | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll need to swap the the side cover and shift arms from the original 3 speed from your truck to the overdrive transmission, as there are some differences. The side plates are a direct interchange.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | While you have both side covers off look at the 2-3 shift fork. It is a common wear point and can cause shifting and popping out of gear problems. Use the best one or try to locate a new one. Fred
