6 members (Rusted Nut, FAST55, KEVINSKI, Wally / Montana, HandyAndy, 1955 1 Series), 47 guests, and 3 robots.
Topics128,090
Posts1,056,018
Members48,430
#980019 10/21/2013 12:35 AM
I was able to find an overdrive transmission out of a `55 210 for my `59 1/2 ton pick up. Got the stock rebuilt 235 and the trans dropped back into the frame today. My linkage arms from my column shift 3 speed don't seem right.
What is the right set-up for me?
1959 Shortbed stepside 1/2 ton project
[Linked Image from i236.photobucket.com]
You'll need to swap the the side cover and shift arms from the original 3 speed from your truck to the overdrive transmission, as there are some differences. The side plates are a direct interchange.
Bill Burmeister
Cool Thanks! I'll tear into that tomorrow and let ya know how it goes.
Update pics of the project here.
http://s236.photobucket.com/user/ol...mp;_suid=1382311001586035394642135925375
While you have both side covers off look at the 2-3 shift fork. It is a common wear point and can cause shifting and popping out of gear problems. Use the best one or try to locate a new one.
Fred
