6 members (Bill Hanlon, 3B, DadsFirstPickup, 1955 1 Series, Jon G, Joe H), 101 guests, and 3 robots.
Topics128,078
Posts1,056,046
Members48,433
#980459 10/22/2013 6:39 PM
Looking for recommendations to replace the rear axle in my 1949 3600 (4 speed with 4.57 rear). Looking for a rear that is most compatible in terms of dimensions, has a high enough gear ratio for highway driving, and ends up giving me either a 5 or 6 lug bolt pattern. Thanks, Charlie
Seems I've read where you can swap the center section out with a newer one and have 4:10 ratio. The original housing stays then.
Not sure about getting 5 or 6 bolt pattern though. You'd probably have to go down to a 1/2 ton style differential then.
