7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 14 New Guy | | New Guy Joined: Sep 2013 Posts: 14 | Looking for recommendations to replace the rear axle in my 1949 3600 (4 speed with 4.57 rear). Looking for a rear that is most compatible in terms of dimensions, has a high enough gear ratio for highway driving, and ends up giving me either a 5 or 6 lug bolt pattern. Thanks, Charlie | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Seems I've read where you can swap the center section out with a newer one and have 4:10 ratio. The original housing stays then. Not sure about getting 5 or 6 bolt pattern though. You'd probably have to go down to a 1/2 ton style differential then.
John | | |
