4 members (Forty9, ShopRag, Hotrod Lincoln, 1 invisible), 118 guests, and 4 robots.
Topics128,261
Posts1,058,342
Members48,485
#980705 10/23/2013 3:28 PM
I've been following this truck's listing and was admiring the pictures because of it's rarity and because I own one. Everything looks the same as mine except the larger wheels and the driveshaft to the rear axle. Anyone know if this was common? or what it may have been transplanted from? I know the 1/2 tons were torque tubed as well as the first shaft in 3/4 tons but I thought all larger trucks were open.
On a side note. Mines about the same condition with extra sheet metal. Maybe I should list it (not!) This guy wants crazy money and apparently still isn't satisfied.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Not a one ton,10 lug with 20 in. tires.
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
My 41 1 ton Long Bed, 134 inch wheel base,4 speed transmission has an open drive shaft stock. It may have depended on the wheel base. My wheels are 6 lug 17 inch split rims.
Check your Vin # that will give you the weight rating for your chassis.
I agree that it is not a 1 ton but rather a 1.5 ton due to the wheels. I checked the 1946 specification manual and it's supposed to have an open driveshaft at the rear. Must have been modified at some point.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
The truck itself is a 1.5 ton Express, however, the rear axle is not original to that truck. From what I've found in the manuals and the Resto Packs, it appears to possibly be a '39 or older 1 ton/1.5 ton axle, which did use an enclosed rear shaft.
Bill Burmeister
Moderated by  Dusty53
