2 members (Otto Skorzeny, Wayne67vert), 116 guests, and 1 robot.
Topics128,147
Posts1,056,798
Members48,454
Hello all,
And if you do, can you offer any insight to installing them without the screws showing inside the roof of the cab? Thanks.
Greenman Wood
'61 Apache Longbed Stepside, 235 I-6
"The duty of a patriot is to protect his country from its government." - Thomas Paine
The roof is a double panel. The marker lights install from the outside with sheet metal screws, nothing will be visible on the inside.
Here's a diagram. Read "Step 1", it references the double panel: http://i645.photobucket.com/albums/uu176/lakeroadster/Chevrolet%20Truck%20Stuff/8i97_zpsd75946d1.jpg
Thanks, John. This really is the best online group ever.
G.
G.
thumbs_up
FWIW, I just put some on my '65. I put some pictures up on this thread: http://67-72chevytrucks.com/vboard/showthread.php?t=601159
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
Just checked them out, Sub. Looks great!
Yep those are awesome thumbs_up Not sure they would like right on my truck... your thoughts? ohwell http://i645.photobucket.com/albums/...Status%20Photos/GEDC1232_zpse66ae036.jpg
Both my 65 LCF60 and C80 have cab lights.
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars.
Never time to do it right, always time to do it over.
Crusing in the Passing Lane
1964 C30 wrecker with cab lights, not sure of the brand or model but these lights are repros of the 1967-72 lights
might have to copy and paste
http://www.flickr.com/photos/67116733@N03/11435948376/
Currently cruising
in the Passing Lane
Rest in Peace
The only thing I might add to the install diagram is to shrink wrap or tape wrap the first few inches of the lamp wire leading from the base where the wire passes though the cab roof. It would be very easy over time for the wire coat to peel and create a short.
Drew
My 57 GMC 370 2 1/2 ton, came with the identical lights as shown by Hot Rod John. Don't know if they were factory installed or dealer installed, but you can tell they are the same age as the truck. Still work too!!
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
I put Factory type Yankee 77's on my '64 C-30 back in '81. Although I tried to find some, they were no diagrams available back then to put them on in the correct position, that I could find anyway. I went to Junk Yards to measure some Big Bolts, only to find out there were more than one variation. The dealer or owner probably installed some of those. Anyway I went by measurements that I belived to be correct and was satisfied with the results. Today you can find those diagrams online. They have been posted a few times over at '67-'72 Chevy Trucks.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
The Accessory Installation manual and the tech sheets, found in the NOS Yankee 77 clearance light box, indicate a 3-cluster & 5-cluster configuration & layout dimensions for installation. We have removed a few roof caps, in favor of a roof cap with no cab clearance lights & saved them, for use as a template, when installing cab clearance lights.
Moderated
Moderated
I have a 72 GMC 1/2ton 1500 4x4 pickup with factory clearance lights ( cluster of 5) and factory bucket seats. I have been trying to identify the model of this truck with no luck. Not very computer literate so my wife does most of the looking. The VIN number indicates a possible Heavy half ton or Big 10 due to the cab roof marker lights??? The side emblems are blank so would like to put correct ones on. It has a 350 with turbo 350. Am just starting to spruce her up but would like to know more about model etc? A friend told me that this was only available as a special order and that usually only available on 1 ton cabs. By the way, the roof marker lights are actually on molded in pedestals in the cab roof. Sorry to be so wordy, I'm brand new at this.
Sounds like the Cab Lights you have are "Fireman's Hat" style, which were pretty common in '72. I believe they were optional on any size truck, although the Heavy 2 1/2 to 3 1/2 Ton trucks got the Yankee 77 type. If the Side Lights are just the "Plain" style, they may be correct for your truck. I would check the Door Jamb Tag to see what GVW the truck has.
Welcome to the site, by the way.
GMC 9500 Fan
Detroit Diesel Fan
