5 members (rfs56trk, 55shaker, DadsFirstPickup, JoergK., 1 invisible), 324 guests, and 3 robots.
Topics128,152
Posts1,057,011
Members48,460
either an old casting ( if there ever was one ) or a home made set up? Some pictures, if anybody has any would be great.
Greg
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
V
VEW Offline
V Offline
My Grumman is stock with updraft carbs. I'll try to get a pic sometime this week if you still want one.
Victor
~ Victor
1957 3100 - moved on
Victor - still have those pics?
A buddy of mine has a 235 in an F-20 tractor (old homebrew conversion). It's got the stock intake and exhaust manifolds both turned upside down, updraft carb and an exhaust stack. I would be willing to bet you could just turn a Fenton or similar dual-carb manifold upside-down as well. The issue will be the exhaust. I'm not sure if you'd have room to run the exhaust in the stock location.
V
VEW Offline
V Offline
Sorry, I misread the topic and didn't see "dual". My updraft manifold is a stock single carb.
~ Victor
"Has anyone ever seen a dual updraft manifold for any GM inline?"
I believe one of the big GMC sixes (maybe the mid-1940's 426?) had a dual updraft setup. My uncle used a retired GMC road tractor to haul BIG boats from his shop in Goodlettsville Tennessee to Old Hickory lake after he repaired them, back in the mid-1950's.
Carburetion specialist
My records show a set of two one barrel carbs on the GMC 616 CID 6 cylinder inline used on the model Z Yellow Coach (bus) from 1931 to 1934; but they were downdraft carbs (Strombergs).
Cadillac used dual updraft one-barrels on the V-12 and V-16 engines from 1931 through 1937, but of course these were not inline engines.
I have no record of any dual single-barrel updraft manifold used by GM on an inline engine.
Jon.
The Carburetor Shop
Allis Chalmers used dual single-barrel updraft carbs on their model L tractor from 1933 to 1942. This was on an 844 CID inline 6.
Not GM, but closest I have found so far.
Jon.
The Carburetor Shop
