5 members (3B, Otto Skorzeny, 55shaker, rick46ia, 57 Drifter), 73 guests, and 1 robot.
Topics128,023
Posts1,055,365
Members48,420
#976035 10/02/2013 3:08 PM
i have a 1112353 distributor that i took off my old 216.
will it work on my 54 235?
my interchange manual says it should be a 1112388 dist and it doesn't even list a 1112353. it's an ac delco.
rolf
1963 c10
rgie #976079 10/02/2013 6:17 PM
Yes it will work, however the drive gear I believe may fail with the later type cam. At least check this out. I wouldn't use it as points may be more difficult to find than later type dist.
1946 1/2-Ton Chevy
rgie #976083 10/02/2013 6:47 PM
The issue is the camshafts... cast iron or steel. The steel will be much harder and will chew up cast iron gears.
HERE IS A LINK TO ID THE CAM AND DIZZY
rgie #979533 10/18/2013 1:10 PM
ok
i found two distrubutors
one is a 2304 the other a 2392 (for a 261)
i'm going to take them apart and clean them up
anything i should know before i start?
thanks
rolf
1963 c10
rgie #979600 10/18/2013 6:34 PM
A rebuilt dist from Advance (Pn 30-1609) is $56+$10core. Includes a set of points and condenser... all you need is the vacuum advance or dist clamp.
They do not come with a grease cup or data plate... other than that for $60 (less if you get the coupons) I would just buy a new one and not worry about gears or worn parts.
rgie #979924 10/20/2013 3:36 PM
thanks
pfarber
1963 c10
rgie #979930 10/20/2013 3:58 PM
Check napa also
I purchased one from there for my 54 235. It came with vac advanced and the grease cup
...pic...
If your new one comes with an o ring as in that pic, remove it.
rgie #979979 10/20/2013 9:44 PM
Thanks guys
i'm gonna take it apart and clean it.
it needs the gear pin replaced
rolf
1963 c10
rgie #980047 10/21/2013 1:38 AM
Check the bushings/shaft for play. I don't know if there are any rebuild kits out there... but springs do wear out and the weight holes can become worn if not lubed... all minor issues.... but that's what causes poor performance.. your timing not being in, well, time.
