1 members (J Lucas),
85
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Sorry to post a new thread for this, but can someone please direct me to where to find threads on Frame Swaps? I'm trying to get more info on putting my A.D. on an S10 Chassis.
Thanks. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Check out Mongos Garage in the links page. He has a lot of info there, Have fun and good luck
Dan | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Try looking at the post at the top of THIS forum. I think you may find what your are looking for. Good luck.
| | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | JUST MY 2 cents make sure the high ride height is what you are looking for. I purchased one of the kits to do this and after about 2 months of work I decided that was not the look i was looking for. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | That's why I don't like the kits. 1: they're expensive. 2: The ride height is too tall. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Search for S-10 Frame Swap here, or just S-10. Or look at my previous posts. There are TONS of threads on it. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thank you gents. There is a bit to chew on. I found a guy with a running S-10 longbox that I think would be a good candidate. One question item that I've read conflicting reports on: some say that I need to raise the height of the bed relative to the cab when mounted on the S-10 frame. If so, doesn't this make the fenders sit higher above the wheels? I don't really want to lower the fenders on the bed, because it has the stamping that parallels the contour of the fender and it would also look strange. For those of you that have done the swap, how did you deal with this, or is it a non issue? | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | People deal with this in different ways. It all depends how low you put the body on the frame, as well.
You can raise the bed 2" and lower the fenders on the bed, but this is not my favorite. It sounds like you have a 54-early 55 bed if yours has the contour on the bed side.
What we've always done with the S-10 swap (done about 5 now) is put the bed in the factory location and raise the bed floor. You only lose about 4" of bed floor in most cases, and it works out just fine.
I don't like the look of a raised bed, they don't look right in my opinion, and you can't do it without lowering the fenders on the bed sides. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Thanks, Colin. I'm beginning to get my arms around this. I believe that if I put my bed on the frame at a "stock" height (I'm looking into buying pre made mounts) then I may only need to lose 2" in bed depth. The "dropped" version they advertise sits cab 2" lower and would require the 4". And yes, my truck is a '54 longbox, which I will be sectioning to make a shortbox.
I'll be hitting you up for info before this gets underway.
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | e-zchassisswaps.com this site has everything you need... and pictures to show you how its done | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | My truck started as a long box as well, and I sectioned the box 9.5". I did mine a little differently though in how I sectioned it.
I saw a 51 last weekend that used the EZ chassis swap kit, the same one that is higher over the frame. The mounts are very well made and look very easy to do, with exception of the rad support which made the truck use a very tiny rad and could have easily used a much larger radiator.
I didn't use a swap kit because of the cost, and because I would rather put the body where I want it than where someone else figured it should go. To each their own though, and that's why each one is different.
My dad's is a '52 on an S-10 frame with a 454, and mine is the 4th or 5th we've done. Feel free to send me a PM or email with any questions you have and I'll do my best to answer. | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Well,almost exactly 4 years after tearing my truck apart, I got it back on the road last Friday. There is still quite a bit to be done, but it now drives like a modern truck/car. The LM7 engine has tons of torque for a vehicle that, I'm guessing weighs less than 3,500#, power steering and brakes are nice to have and eventually I plan on putting in air conditioning as well. For now I'd just like to put some miles on it.
The link in the above post is still active and it shows the process I went through to get it to this point. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 |
| | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | Nice job Lorb, congrat's on getting it on the road. I'm probably on the same schedule until retirement as are many others.
On the other post, a 454 on an S10 frame huh? Reckon Pop ever gets to 20% throttle? I don't know how he keeps the tires from spinning all the time. Good for conversation though.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
