2 members (cmayna, CuzzFuzz),
60
7
Mod | | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have an after market dimmer switch from Ron Francis wire works on the turn signal stalk. while in KC last months the low beam lights went out but when i hit the dimmer for high beams the hi came on but the low would not work. when i got back to the hotel i tried again then they went off again and has been intermittent since. i replaced the dimmer relay but made no difference. if i continue to use the switch the switch ceases too work at all, will not dim the high or low, high stays on..
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I talked too the company said that and they said it rarely happens that the switch goes bad.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If they admit it's a bad part they're out the money so they'll be loath to admit it's a bad switch.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Maybe just maybe it could be that the low beams have burned out. it seems like we look for the worst and overlook the obvious. will buy new bulbs at work tomorrow and see if that does it. i have wanted to put in higher out put bulbs any way.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I thought you had checked that already... you would normally replace a light before a switch
but the floor type switch on my International was always an issue Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Instead of buying new parts willy-nilly, buy an multi-meter and find the problem. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | speaking of that, I was going to use mine tonight at the country place and I had forgot to turn the thing off from using it 2 weeks ago and it was dead, dead..and yup, I did not have another nine volt battery handy
have you ever done anything so stupid in your life Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | It was the fact that both low beams went off at the same time as far as i could tell and they worked on way back from KC. then started acting up a couple of weeks later. as far as testing i would have too take it too a shop and i am trying to eliminated somethings before i take it in. the high beams freeze and the switch will not work so i tapped the box under the dash and it will work, curiouser and curiouser. and i can no longer squeeze under the dash.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | take it to your shop guy,,, let him figure it out sounds like it is the switch or lose wire or both Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Ron, you might be rewarded with a real JOULE Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2012 Posts: 85 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 85 | Using probability logic, bulbs are probably fine; they probably did not both burn out at the same time. Dimmer switches rarely fail. Most probable and 1st place I would, look is low beam connection from dimmer to where the wire splits to go to left and right headlights. Good chance a wiggle of the connection of the wire at the dimmer may make lights illuminate. For something like this you can get by with a simple circuit tester if you have one rather than a multimeter. http://www.autozone.com/autozone/ac...ster/_/N-26lp?itemIdentifier=222515_0_0_Good Luck Mikey | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | your statement about dimmer switches rarely fail.. ever drive a 70 International half ton
I think Ron has one of those custom switches, probably not on the floor like the stock one..
Hey Denny, you have your quota for agreeing with me and Charlie for the month....lol Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I had a headlight issues and changed everything and eventually made my way back to the contacts on the firewall, this was on a different car though. You can bypass the switch with a jumper wire to see if your low beams work. This will tell you if it is the switch or not. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Denny, does your meters get hi def? i am going to test at the bulb plug in Saturday. i wanted to take them apart to remove a button mount in the bulb that distorts the light. yes it an after market from Ron Francis wire works. no floor switch it is a button the end of the turn signal switch. my wires a mostly concealed in looms and hard to track down. trying not to spend any more money on it than i have too. will take it to him if need be. These are the lights. Theses are the ones i want.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | trying not to spend any more money then you have to and the ones you want are $79 a piece.............put the stock ones back in..
and leave them along , for that price your ace mechanic should fix your problem Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I tested them last night with a volt meter and it seems like the low side is not getting any power. i got a Ron Francis catalog in the mail yesterday and it has a trouble shooting section and they say that rarely does the dimmer switch go bad and i should check the headlight switch, it is one of theirs. their is a bracket inside of the light that i think is distorting the light path so i removed it and will check the results out today.
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | You said it got to the point that it wont switch at all, stays on high all the time. It sure sounds like a bad switch.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Yes, j, if you click the dimmer switch to often it freezes and if you smack the box under the dash it works again.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | then carry you a big stick while driving at night and not spend any money on it...lol
post a pix of the switch...
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | That's a ton of cash for a "cool" housing. You would do better with a Hella kit for a few bucks more.
Ted My ride but looking for a Deco Bolt for the wife.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | It will not switch back, when it is high and you click the switch it will go to low but the lights don't come on. if you use it to much three or four click it will freeze. will work on it this weekend and test the bulbs then the switch. Doesn't show much.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Bought new bulbs and still no low beams. Maybe i will have to do as joker suggested and take it to the shop and since he has volunteered to help me out financially that is what to do.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Well joker get ready to pony up. my mechanic called yesterday asked if i wanted to bring the truck by and have it looked at. so i dropped it off on the way home from work. i had decided to wait a while but maybe this is an omen.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Is the check in the mail joker? it was a broken wire under the dash. he will deliver it today, don't know the price.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'll bet he found it using a multi-meter. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I did use a multi-meter and found out that i was getting power from the switch and dimmer but not too the low beam side of the socket. beyond that i had not a clue. so i took it to the man who wired it.
