4 members (1955 1 Series, baldeagle, Shaffer's1950, 1 invisible), 95 guests, and 1 robot.
Topics128,015
Posts1,055,335
Members48,419
#979121 10/16/2013 9:59 PM
I have a bent push rod in my 235.Will one from my old 216 work?
Did you just bend one?
They're 5 bucks at Summit
http://www.summitracing.com/parts/slp-rp-3018?seid=srese1&gclid=CMzV-62onLoCFadj7Aod22MA4g
I wouldn't push it (hey look a pun!)
Bent push rods are usually caused by seized valves.. Seized valves are commonly caused by starting an engine on old gasoline.
bucketlist51,
What year 235?
What length push rod?
Cletis #979148 10/16/2013 11:30 PM
Ex Hall Monitor
Ex Hall Monitor
Exactly right.
It's a 1955. My son, the same one that put the oil holes facing up on the rocker shaft, probably didn't set the rods onto the ball end of the lifter. He also bent the oil feed tube. He's only 40 and has maybe never worked on an engine that didn't have overhead camshafts
If it has solid lifters the push rods fit 1941-55 truck with 235 and 1953-55 pass with stick transmission and are 10 37/64" long.
If hydraulic they fit 1950-62 pass and are 11 1/4" long.
My Blog
