0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | I have a bent push rod in my 235.Will one from my old 216 work? | | | | | Joined: Sep 2013 Posts: 6 New Guy | | New Guy Joined: Sep 2013 Posts: 6 | Did you just bend one?
They're 5 bucks at Summit http://www.summitracing.com/parts/slp-rp-3018?seid=srese1&gclid=CMzV-62onLoCFadj7Aod22MA4g
I wouldn't push it (hey look a pun!) | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Bent push rods are usually caused by seized valves.. Seized valves are commonly caused by starting an engine on old gasoline. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | bucketlist51, What year 235? What length push rod? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Seized valves are commonly caused by starting an engine on old gasoline. Exactly right.
| | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | It's a 1955. My son, the same one that put the oil holes facing up on the rocker shaft, probably didn't set the rods onto the ball end of the lifter. He also bent the oil feed tube. He's only 40 and has maybe never worked on an engine that didn't have overhead camshafts | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If it has solid lifters the push rods fit 1941-55 truck with 235 and 1953-55 pass with stick transmission and are 10 37/64" long. If hydraulic they fit 1950-62 pass and are 11 1/4" long.
See the USA in your vintage Chevrolet! My Blog | | |
