2 members (carbking, TUTS 59), 108 guests, and 2 robots.
Topics128,029
Posts1,055,416
Members48,422
#97926 11/03/2006 10:22 AM
Junior Member
Junior Member
Yes, this post is in regard to a light bulb:
I need a bulb. One for the overhead interior light that has two terminals and the little "teets" lined up - not offset like a regular dual filament bulb (think 1157).
Soooo: I grind off one teet just to get a bulb to fits and it turns out to my surprise that the same bulb-filament for this application must run to both terminals and the brass must not be used as a ground. The 12VDC flows into one term of the bulb and out the other through a wire to ground at the rheostat.
If I put in a regular bulb with a "base grounded filament" the light always stays on since the switch is on the ground side and the grounded bulb short-cuts it.
Long story for: What's the number of the correct bulb for an overhead cab light application in a '58 Chevy?
#97927 11/03/2006 5:28 PM
The book shows bulb #1004 auto-interior & marine.
Stuart
#97928 11/03/2006 6:29 PM
Junior Member
Junior Member
Wonderful!
' guess it's 'bout time to get the book.
Thanks Stuart.
