8 members (jmoore, TUTS 59, 1955 1 Series, Gdads51, Phak1, Woogeroo, DaveV, 1 invisible),
91
Mod | | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | I bought a nice looking 1962 235 last night, I was told it was out of a truck and it still has it's bell housing with the hydraulic slave & arm on the right hand side. My 55.2 3600 has two "studs" sticking up out of the frame for the motor mounts. The '62 Engine no longer has the holes or bosses cast into the block to mount the brackets. The '62 engine has a front mount bracket on the timing cover flange under the harmonic balancer with a rubber pad and two studs sticking through the bottom. I assume I need the bottom half of the mount (or bracket) and then do I simply drill the front cross member to add the bracket. If so are there any drawings etc to help me center it and is there a lower retainer or anything else I need?
| | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | LOL yup been there and done that. I bought a I think a 1960 235 for my 1956 3100 fortunately I decided not to use that motor and just use it for parts. What really was funny about that was in Patricks catalog when I called him before the he warned me about that block and I marked the block number in the book a few month later I forgot the book and I thought what are the chances of me getting that one out of all the other ones and guess what Bingo well enough of that boring story Try this not sure if its what your looking for or You may want to call Patrick's for some good advice http://www.stovebolt.com/techtips/motormount_235.htmlhttp://www.stovebolt.com/techtips/engines/motor_mount_front/index.htmlThat was found at this thread 235 front motor plate good luck
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | Now I'm even more confused. I thought I took the original 235 engine out ofh my 55.2 3600 and it had 2 front motor mounts one on each side in the area forward of the fuel pump. There was a bracket on each side that bolted directly to the block. The 62 235 I bought has a single front mount that Im reading all the trucks had??? My truck doesnt have any holes in the front cross member where Im assuming the mount would bolt to. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1955 2nd through 1959 trucks and 1955-57 pass used the front side mounts. If you decide to mount it on the front center you will need to make up your own brackets.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | I'm not sure but that newer engine should already have those mount points drilled and tapped. Just use the mounts off the engine that came out.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | Thats my problem, the new engine's casting isnt the same. It doesn't have the raised platform or the holes | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1960-62 engines do not have these front side mounting provisions.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | That's the issue I'm faced with. My "new" '62 engine has a front mount with no provisions for the two "corner" brackets the original engine had. My truck doesn't have provisions for the front mount and I cant find any information as to how to make it work. | | | | | Joined: Sep 2011 Posts: 1,462 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,462 | My truck doesn't have provisions for the front mount and I cant find any information as to how to make it work. Might be able to trade it to somebody for a pre '60 engine.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1958-62 engines have provisions for center side mounts. A creative person could mount it from there to the frame.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | Hi, I have a 1962 261 in my 55 cameo, I used the 60 series front motor mount that was on the engine. My front cross member had the holes for the front mount. Bolt your engine in on the rear mounts and set the engine on the front cross menber. Mark where the studs touch the cross mender and dill you holes. Mine had a rubber mount that went under the cross menber for the front mount. | | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | Thank you, that's what I was hoping to do. | | | | | Joined: Mar 2013 Posts: 45 New Guy | | New Guy Joined: Mar 2013 Posts: 45 | Update: This is what we did as noted above. Set the engine in, marked the front cross member and drilled then slotted the holes for adjustment. Ends up with the nose of the engine up about 3/4" from original as seen when we tried to fit the lower radiator hose. Simply had to match a hose up and works fine. Also there will be an issue with the throttle linkage as the pivot on the '62 engine is farther to the rear. used the '62 pivot and after tweaking it so the carb linkage clears the '55 manifold works fine. We will have to shorten the throttle pedal rod but will get to that later. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I drill and tap the blocks that do not have the front pivot. I then install a pipe plug that I drilled and tapped for the stud. See picture. Another view.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2012 Posts: 60 'Bolter | | 'Bolter Joined: May 2012 Posts: 60 |
Proud of my taskforce! 1959 3600 long-bed. the ultimate work truck!
Rick Restivo Valley Center, CA.
| | | | | Joined: Aug 2013 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2013 Posts: 60 | What a small world. Hi DrDarby, it's Dan Miller!
Funny to see you here.
Dan
1939 1/2 Ton 1968 K20
