6 members (klhansen, tesa, Gdads51, treegrower, carbking, Wally / Montana), 55 guests, and 1 robot.
Topics128,090
Posts1,056,022
Members48,430
#97852 05/14/2007 10:16 PM
Apprentice
Apprentice
i have just converted my 51 from 6 to 12v.the main reason was so i could fit an electric wiper conversion.everthing works fine apart from it apears not to be charging,not acording to the amp meter anyway.when it was 6v it worked perfect.the wiring is new,so is the regulater.the generater is re-con.the only differance is the 6v regulater was a 3 bobbin and the new 12v one is only 2.i have measured the output of the generater on the A and could only get about 2 volts from it. any ideas?
#97853 05/14/2007 10:30 PM
jon boy jonny,
I'm not real clear on your terminology. If you are using a actual generator, not a alternator, your voltage regulator should have three terminals which connect internally to three coils...they look like sewing machine bobbins, is this what you are referring to. If this is true, I don't think your voltage regulator is correct and the charging system will not work properly.
Stuart
#97854 05/14/2007 10:32 PM
Do you have a generator, or is it an alternator? Generator wiring is usually identical between 6V and 12V and the generator regulators look the same, but have different part numbers. Alternator regulators look different or are internal to the alternator.
A generator should have an armature wire and a field wire, and could have a ground wire. Your workshop manual diagram should show what goes where.
#97855 05/14/2007 10:46 PM
I was thinking the voltage regulator proper would have three terminals; Batt, Gen and Field...does this sound correct.
Stuart
#97856 05/14/2007 10:48 PM
Apprentice
Apprentice
atomarc
yes thats what i mean about the coils(bobbins)the 2 coil one i have fitted has 5 conections these are A+ A F D E .i have it wired as F to field,D is to the armature, E to earth and the battery goes to A
#97857 05/14/2007 10:51 PM
Apprentice
Apprentice
ATOMARC
yes thats whats on the 6v regulater
#97858 05/14/2007 10:51 PM
Stuart, that is correct for the regulator.
#97859 05/14/2007 11:10 PM
Riding in the Passing Lane
It sounds to me like he,s got an alternator external regulator.
1972 Chevy c10 Cheyenne Super
#97860 05/14/2007 11:28 PM
jon boy jonny,
I can see your address is on the other side of the pond. The markings on your regulator aren't the traditional items you would find on a stateside regulator. This doesn't mean it won't work though. Is your generator a Delco or unit made in the USA or is it something you have adapted to fit and are using a regulator compatible with it.
The third 'bobbin' that seems to be missing would be the cut-out relay. Did you have some paperwork that told you how to connect this regulator and indicated it would work with your generator. These things aren't hi-tech, but they don't work well when you just mix and match.
Stuart
#97861 05/15/2007 7:33 AM
Apprentice
Apprentice
stuart
its a delco genarator,and the regulator is a lucas type(lord of darkness).thinking about it last night i am sure there is not a earth strap between the engine and the frame.off the battery there is one strap to the frame and one to the body.i have taken both the generator and regulator off to get them bench tested.once i know these are both good i will but them back on,and fit a big earth strap from frame to engine.
#97862 05/15/2007 3:08 PM
jon boy jonny,
On a hunch I looked at the Lucas regulators thinking that you might have done this. Although the terminal designations are different, there description indicates you have it connected properly. Did you polarize the generator. On your Lucas setup, I think a small jumper wire would be momentarily touched between A (BATT) and D (ARM) terminals. I wonder what the A+ terminal is used for?
Stuart
#97863 05/15/2007 3:26 PM
Quote
The earth (ground) strap shouldn't be the culprit if it worked as a 6v. In fact, if your engine didn't have a good enough ground, I'm pretty sure that it wouldn't fire for you.
However, you can NEVER have too many ground straps, so definitely put that srap on the engine.
#97864 05/15/2007 8:58 PM
Apprentice
Apprentice
stuart
the A+ is just an ancillary terminal.my mistake there is already an earth strap from frame to engine.i think i polarized the genarator, the test shop will tell me if i havent!
keep you posted
jonathan
#97865 05/17/2007 10:46 PM
Apprentice
Apprentice
it would seem that my genarator is ok and so is the regulator. the auto electric guy has told me that, as automarc suspected the two components may not compatable.its something to do with - and+ field windings.i will know more when he comes to look at it on monday.
#97866 06/02/2007 4:59 PM
Apprentice
Apprentice
sorry for the delay.its fixed!it was indeed the lucas regulator that was not compatable with the ac delco regulator.let this be a lesson to you all that some things do not mix!.my local american parts supply outlet got me the correct one within 2 days,but it cost me three times what the lucas one did.but at least it works.thanks for all the input.
cheers jon
