Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Sjm, Hotrod Lincoln, klhansen, 1 invisible), 129 guests, and 5 robots.
Topics128,281
Posts1,058,464
Members48,490
#978217 10/12/2013 9:47 PM
I am reading that I should add a few drops of oil to the generator. It is original, and doubt that anything has been serviced in years. The service manual says to add a few drops of oil in the two oil cups.
Which are the oil cups? I see two plastic or rubber capped openings on the back end of the generator, and a single opening with a cap that is spring loaded closed. So, is the manual referring to the two openings on the back, or am I supposed to add some to this other opening as well? If not, what is the third opening for?
Steven
1953 3100
Melbourne, FL
Veteran
Shaanxi #978223 10/12/2013 10:32 PM
> Two generator oil caps identified by "2" in circle
> Two generator oils caps identified by red arrows
(I hope that Ken Warner of Glassic Generator doesn't mind that I doctored a photo of one of his wonderful restored generators.)
- Lonnie
- Lonnie
My '54 3104
Shaanxi #978243 10/13/2013 12:02 AM
Yesterday I was reading in my 1956 Chevy 3100 manual the generator uses light engine oil or No. 20 engine oil every 1,000 miles. It also noted the successive refilling of the oiler should only be performed at the rear oiler. Successive fillings should not be made at the front oiler. Over oiling at the front oiler may result in damage to the generator.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
Shaanxi #978319 10/13/2013 8:25 AM
LonnieC,
I will try and get a pic today, but mine has two cups in the back end, and the same one up front. ???? Maybe it is off of something else.
I know that my motor is a 254 and was off a car originally. That is all I know.
Oh, and thanks for the links. They will be a BIG help! He really took the time to document everything. I wish I had that time.
1953 3100
Melbourne, FL
Veteran
