2 members (JoergK., TUTS 59),
120
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 36 | Hey folks I'll do my best to describe it but it's for a 1948 216 Chevy spray oiler- it's a bit of pipe or nipple or tubing that's about an inch long that sticks out of the bottom of the block. It sticks down and makes a slip joint that the the oil pan oiling assembly sits over connecting the pressurized oil from the oil pump/oil distributor to the oil pan oiling system. From what I can tell by looking inside it is about an inch long. You guys should get the idea but I can post a pic this evening if necessary. Mine is slightly damaged and I would like to replace it but my books don't list a name or part number. In fact they don't even mention it, lol Any help appreciated folks, freezerburn
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If it's brass it's probably in the plumbing hardware section of your local builders supply...
| | | | | Joined: Dec 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 36 | Thanks CASO but it's steel anyone else have any input here? Be cool, freezerburn | | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | I believe that's simply a piece of 3/8" steel tubing that's press-fitted into the block. You could probably run a tap into the inside, and use a bolt, a nut, and a stack of flat washers to pull it out. Then just tap a new piece into place with a little red Loctite to help hold it in. Jerry
| | | | | Joined: Dec 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 36 | Correctomundo, after a bit of finaggling it is just a piece of 7/16" o.d. tubing. I ordered up a foot so if anyone needs a piece I'll drop a bit in the mail for you:) -freezerburn | | |
