| | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | The tachometer I am looking at is calibrated for a "std pt ign, 2 IMP/rev, 6 volt pos or neg grd". They also have them for 1 & 3 IMP/rev, which one should I use? | | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Use the 3 impulse per rev item. It takes 2 turns of the crankshaft to make 1 turn of the distributor so the 6 cylinder distributor will open the points 3 times every crankshaft turn. The tach signal comes off the distributor side connection of the coil. Jerry
| | | | | Joined: Aug 2009 Posts: 311 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 311 | Thanks Jerry, without your help I surly would have ordered the wrong one! Curt | | |
