4 members (Danielbolt, Rich'sToys, 54farmtruck, 1 invisible), 96 guests, and 0 robots.
Topics128,157
Posts1,056,875
Members48,456
8
8 Offline
The tachometer I am looking at is calibrated for a "std pt ign, 2 IMP/rev, 6 volt pos or neg grd".
They also have them for 1 & 3 IMP/rev, which one should I use?
Curt Warren
Salt Lake City
1948 1.5ton Loadmaster
http://photobucket.com/48loadmaster
Use the 3 impulse per rev item. It takes 2 turns of the crankshaft to make 1 turn of the distributor so the 6 cylinder distributor will open the points 3 times every crankshaft turn. The tach signal comes off the distributor side connection of the coil.
8
8 Offline
Thanks Jerry, without your help I surly would have ordered the wrong one!
Curt
Curt Warren
Salt Lake City
