Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (3B, kades51, TooMany2count), 134 guests, and 4 robots.
Topics128,283
Posts1,058,513
Members48,490
#97795 10/26/2006 7:47 PM
Some of the old trucks had the ignition switch that you could turn on and remove the key. The story was that Mr. Farmer wanted to jump in it and go without remembering to bring the key!
I don't understand what kept the ignition system from cooking if this tale is true. How else would it have worked, or what am I overlooking in my understanding?
Stuart
#97797 10/26/2006 8:14 PM
My dad had a Fj0rd Aerostar like that.
you had to put the key in to turn it on, but you could leave it running and pull the keys out.
#97798 10/26/2006 8:19 PM
My '94 F**d Ranger is like that. The warning buzzer goes off when the door is opened to remind you that you left it that way.
#97799 10/26/2006 8:27 PM
Does this mean if the truck was running, the key could be removed from the lock.
I was under the impression that the key could be turned to "on", then removed. When someone wanted to start the truck, he merely pushed the floor starter...no key necessary.
My question was how could this be possible without the ignition being energized and ready to roll!
Stuart
#97800 10/26/2006 9:14 PM
OH!
Yeah. That's a question... How WOULD you keep the ignition from cooking?
#97801 10/26/2006 9:43 PM
There was a lock, off, on, & start(or just lock, off, & on if stomp start) position on the ignition switch-if it was "off" the key could be removed & the "ears" on the lock cylinder could be used to start the vehicle. It would then only go to "lock" if the key was re-inserted. Even a knife or screwdriver could also be used to turn it. I have seen many trucks being used that the key was long lost, just turn the cylinder. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#97802 10/26/2006 10:21 PM
Brian,
That's what I had forgotten...the ears! So the driver would turn the key to ON without the key by using the ears on the lock, then turn it back to OFF to shut it down. If he wanted to disable this function, he had to insert the key and turn it to LOCK..is this right.
Stuart
#97803 10/26/2006 10:43 PM
Riding in the Passing Lane
Lot,s of times these old locks get worn so the key pulls out in the on position but were not intended to.
1972 Chevy c10 Cheyenne Super
#97804 10/26/2006 10:51 PM
Ex Hall Monitor
Ex Hall Monitor
My 55 1st was that way. I never used the ignition key. The "key" I used was a church key I kept handy. Slip the end in the switch, turn it & stomp the starter.
#97805 10/27/2006 12:31 AM
right!! the switch has three positions. on,off and lock. you could use it as a regular switch,using the key,,or remove the key and turn it to the right to shut it off and straight up and down to start the truck.(w/o the key.) i have one right here in front of me.
