7 members (D B Cooper, 55shaker, GMCJammer51, MickeyP, ndkid275, Phak1, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Has anyone found a source for rubber side bumpers attached to the liftgate? Second question: I am transplanting lift gate into panel/barn doors truck. The upper original receivers for the hinges are very light so intend on beefing them up on install. Has anyone done this? Cheers | | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Jim Carter sells the rubber bumpers, he also sells them on eBay.
Idon't think you need to beef up the hinges, just rebuild them. I experimented with modifying them and was happy with the results. Don't forget there were two styles, the early style was the weakest and I believe with slight modifications they can be interchanged........g | | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Thanks. Mine were 49 and they did not look that strong. I beefed them up a little and have made the slots to hang them in the sill of the panel truck. The roof supports are slightly in the way so need to cut and spot weld a little. Does anyone know how much lateral play is okay in the hinge? cheers | | |
