1 members (delky),
130
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | won't need any heat, those will hammer out easily using any piece of bar or rod, you could likely even pry them up with something like a wonder bar in the slot beside the bend
Bill | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Pry? Really? Thought they would be too hard to do that. Might try that first. Thanks again. You have been plenty helful with this sill.
Drew
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Mine were like that too... not as severe of a cave, but still not flat. I left mine as it was | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Mine were broken, fatigue cracked. I determined the back of the bed was bouncing due to broken wood blocks. When re-assembled I will use real hard wood and rubber pads. As for the cross rail I will rebuild it with 10 Gauge steel. Mar-K wants$100+ for this repairable part. Good luck with yours, doesn't look that bad- Merry Christmas!
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Until this topic popped up again, I had forgotten to do a follow up. It all worked fine just prying with a flat bar with no heat needed. I than body worked everything square. The bed and tailgate are reinstalled although not bolted down yet as I haven't acquired the oak bed wood my son-in-law made for me. I have the hard wood blocks, but have misplaced (It's an age thing.) the rubber insulators. Anyway, thanks for the advice I've received. As usual, Stovebolters always come through.
Drew
