| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I had just turned onto the last 2 mile portion of my nice and long afternoon cruise when I 1st noticed a vibration in the frontend. It would come and go but after a minute or two it turned into a thump, thump, thump and the vibration got so bad I had to find a pulloff. it wasn't going to make it home unfortunately. Everything looked good until I pulled the left front hubcap and the problem was VERY obvious. Only 2 bolts was holding the wheel on and they were very tight. The other 4 lugnuts were still tight but they were only holding the broken pieces of the wheel. I'm going to guess the metal was fatigued from the pitted corrosion and finally let loose. I dunno, The pitures tell the tale. Man am I glad I had a good spare and the tools to change it. Wheel pieces front rear | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow, that is pretty nasty looking failure. This is the first time I have seen a posting like that. | | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | THats scary... makes me think twice about using OEM wheels... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You were lucky you got stopped before it all broke loose.
That is something people don't think about checking. Everyone on this board who is running OEM wheels ought to pop the hubcaps and have a look before their next drive. Thanks for sharing your misfortune. | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Good point Cletus.
We also should commend Volfandt for having a spare and the tools to change it. Many don't.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Inspecting wheels and tires should be part of a regular routine. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | That wheel has had a very hard life. Look at the pitting and "patina" Not a typical wheel for sure. Good thinking with the stop. Any stop before catastrophe is a good stop. I have seen OEM wheels fail but always because there was a reason. Yes curbs are a reason. And as this one shows, corrosion is a very good reason. What size is the wheel? 15 inch? Fairly easy to find. 16 inch? Tougher to find. Now how about after market wheels? Oh yeah, seen them fail too. Most common fail is loose lug nuts. But this is a new fail to me.That vibration you felt was the wheel flexing, a lot. The thump was the breaking of the metal and that was the end of it. Great save.
Steve H
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Deep Corrosion pitting is a stress riser where a crack will start from. And from the looks of it, there was some seriously deep corrosion on that wheel. Wheels are probably the most highly stressed item on a vehicle and the most catastrophic when they fail. I'd agree with the rest of the guys, don't take a chance on a less then near perfect wheel, it could save your life, or that of another.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | The wheel is an OEM 16". Since I'm the 2nd owner of the truck I'll bet a $$$ to a donut it's original and came w/the truck new. The truck came with 5 wheels/tires. I've picked up another good wheel & tire in a trade. This busted wheel was highly pitted & corroded. The others aren't. I've checked the others for any stress cracks etc., and all seem to be in good servicable condition. I'm guessing this was the spare that lived most of it's service life bolted to the under bed spare carrier. All the tires were 600x16's w/tubes but were mismatched brands. All tires have been replaced w/4ea used Wrangler ST 225/75R16's and are tubeless. Large whitewalled radials are on the wish list. The spare is still a tubed 600x16 but it's servicable for spare duty for now.
Normally I rotate the tires on all my other vehicles during oil changes (5k miles) but since the interval for the 3100 is shorter by 1/2, I'll be popping the hubcaps and checking the wheels even when not rotating. Dave
