8 members (cmayna, Gray_Ghost, Donf, Otto Skorzeny, Gdads51, Jon G, Forty9, Shade Baby),
104
0
Mod | | | Forums66 Topics128,118 Posts1,056,307 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Hi Guys, what is done on the rear axles to seal them properly on a 41 1.5 ton? I have what looks like a donut surrounded by a metal gasket on each side. Do I need to replace the donut? Can I reuse the metal gaskets with a little sealer? If either need to be replaced, is there a source? Thanks in advance. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tomcoe, from how you describe it it sounds like you have the type of seal which seals around the end of the axle tube. This type of seal was used when you had grease packed bearings in the rear hub. As far as I know these seals are made of unobtainium, (they are no longer available). If you clean all of the grease out of your rear hubs you can lube the bearings with diff. oil, just eliminate the seals at the outboard end and replace that with a gasket between the axle and the hub. Make sure the diff. oil is up to the level of the fill plug on the cover at the rear of the diff. housing, if you jack up the rear of the truck first on one side and then the other, that will allow lube to run down the tubes into the hubs before you drive the truck, any excess oil will level out when the truck is back on the ground, hope that helps. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | As 3B said remove the seals and let the diff oil lube the hub bearings. I would add oil to the diff before jacking up each side and again after to ensure the diff is full after each hub gets its share. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Oh before you do this ensure that the inner hub seals are in good condition and not a felt seal,they must be a rubber lip seal capable of retaining the oil and keeping it out of the brakes. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | So essentially, I will be eliminating what I'm calling the donuts and just bolting up the axles to the hub with a gasket. So, no chance that the axles will be in too far then since the donuts are about 1/2 inch thick? Thanks for the responses! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tomcoe, could you post a picture of the "donuts"? | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Sure, but it will be Monday, the truck is in a buddy's shop. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | So essentially, I will be eliminating what I'm calling the donuts and just bolting up the axles to the hub with a gasket. So, no chance that the axles will be in too far then since the donuts are about 1/2 inch thick? Thanks for the responses! Yes pictures please after that statement I am not sure that 3b and I are on the same page with you and would hate to give you incorrect info. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | O...k... (head hung low) it is with great humility that I update with what I thought was some sort of donut was just a very dirty, thick axle face.... no donut. So I understand what to do now. Thanks guys.... humble tom.. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Oh my I guess the first step to restoration is to thoroughly clean everything wile disassembly.Oh don't forget tag everything and take lots of photographs ziploc freezer bags and a sharpie helps. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I do those things. Normally, I'm pretty competent.... normally... haha. Honestly, the way they looked laying there dirty, closely resembled a type of wax donut, even with layers and some separation.... but alas, it was just a case of dumbassity. I always clean right before reassembly as parts reveal more clues for reassembly. Just an old habit of mine when I'm working on 10 things at once. | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I just stress organization because it is my weakest suit LOL. If I stress it to others it will make me better at it right??? | | |
