8 members (JoergK., MickeyP, EchoBravoSierra, FAST55, Forty9, Joe H, 55shaker, 1 invisible),
43
Mod | | | Forums66 Topics128,175 Posts1,057,118 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 5 New Guy | | New Guy Joined: Feb 2013 Posts: 5 | Hi everyone. I have a 36 1/2 ton and I am getting thet parts together to upgrade the drive train to a 54 235 with a mechanical speedo t5. I have the engine/trans and I found a 37 truck bell housing. Got the adapter for it too. I still need an open driveline read end for it. I want to keep my stock wheels so I need a 6 lug rear end that is as close to the original width as possible. I was told an 85 k5 blazer rear would work but after getting one I found that is a lot wider. Stock is right about 58" at the outer face of the drum and the blazer one is about 64" A bit too wide to maintain the stock appearance I am going for. Anyone know what axle would be the closest and have the right lug pattern? I'm sure its been done before so any tips would be great!!! Thanks Ron.. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I used a '65 Chev half ton rear end in my 46, later 60s truck rear ends are wider. A buddy is using a '60 truck rear end in his 36 pickup with original skinny rims and it fits and looks good. BTW if you need 17" artillery wheels we have several spares. Jim PS. Love my T-5! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Either the S-10 two wheel drive or four wheel drive would work. One of the two is six lug, BUT be sure to match you brakes. A small differnce between front brakes and back brakes is OK, but watch the combination of sizes that you are using. Don't over brake the rear.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You can also use a 1940-50 1/2 ton axle housing so you keep stock matching Huck brakes and use a 1955-62 center section to have open drive line. This combo works great. I do not like changing to a rear end with better brakes on it than the front. This can send you into a tail spin on panic stops. If you are updating the front brakes than a rear end with Bendix brakes is fine.
See the USA in your vintage Chevrolet! My Blog | | |
