5 members (Bill Hanlon, Gdads51, 50Chevy3100, Charles in CA, 1 invisible), 59 guests, and 6 robots.
Topics128,095
Posts1,056,078
Members48,433
#976633 10/05/2013 11:01 AM
I have a 1955 1st series with open drive line. It the original rear end with 3:90 gears. I have had the pinion seal replaced twice this summer. Each time after driving it and then parking it, there is oil on the floor. Still leaking. Any ideas?
Larry
nels1954 #976635 10/05/2013 11:05 AM
If everything was done right in doing the job, then the last thing left would be a worn or pitted yoke. You may need to put a speedi-sleeve on it.
My Blog
Riding in the Passing Lane
Like Pre says. Also make shure the bearings are not loose. You may need to put some RTV on the splines & washer. Sometimes the grease can leak through the splines.
1972 Chevy c10 Cheyenne Super
nels1954 #976755 10/05/2013 10:03 PM
Gas Pumper
Gas Pumper
I just finished do this and used a speedi sleeve. Perfect solution to the problem. Change the seal at the same time.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
The shop that did the work has done good work for me in the past. After they installed the first seal and it leaked, they were surprised. Took it back to them and they did the job again. Two days later they called and asked about the seal. Still leaking so its going back to them as the job is under warranty. I'm just trying to understand the problem. I have not heard of a speedi sleeve.
Larry,
It looks like you are referring to a leak at the front (forward side) of the drive pinion (not a leak at an axle seal)?
Are the 55-1st parts similar to 1955-2nd parts?
The problems might be (I have had all three problems on a similar GMC pinion seal):
- wrong size seal (#21 companion flange oil seal)
- wrong companion flange (#23)
- groove in the seal mating surface on the companion flange (#22)
Dave and Wrenchbender: is the companion flange called a (rear) u-joint yoke?
If there is a repair sleeve available for the companion flange?
nels1954 #976835 10/06/2013 10:51 AM
1955 first uses the same parts as 55 second.
Yes #22 in your link, "companion flange", if the same thing as a yoke.
My Blog
As shown in Tim's link, it is the #22 seal. Seams like such a simple fix. I would do it myself but already paid the shop to fix the problem. Its hard to believe the shop replaced the seal twice and it still leaks.
Is the shop experienced with these early differentials that use a crush sleeve between the pinion bearings?
My Blog
Just got the truck back from the shop. The problem is finally fixed. New pinion seal, carrier gasket, cover gasket and axle seals. Lots of excuses from the shop. No additional charges.
1949 Beast
1949 Beast
Be sure to check that the axle housing is venting properly, too. There is a vent, that when plugged with dirt or whatever, would allow pressure to build up and push fluid out of the weakest seal.
nels1954 #1031454 05/27/2014 11:31 AM
I wanted to ad to this post that the speedi-sleeve and pinion seal part number for a 1955 first series are:
Speedi-sleeve 99170
Pinion seal 17727
These are both made by SKF
I got these from NAPA and they worked perfectly
Joe
1955 First Series 3100
