0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | I have a 1955 1st series with open drive line. It the original rear end with 3:90 gears. I have had the pinion seal replaced twice this summer. Each time after driving it and then parking it, there is oil on the floor. Still leaking. Any ideas? Larry | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If everything was done right in doing the job, then the last thing left would be a worn or pitted yoke. You may need to put a speedi-sleeve on it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Like Pre says. Also make shure the bearings are not loose. You may need to put some RTV on the splines & washer. Sometimes the grease can leak through the splines. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I just finished do this and used a speedi sleeve. Perfect solution to the problem. Change the seal at the same time. | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | The shop that did the work has done good work for me in the past. After they installed the first seal and it leaked, they were surprised. Took it back to them and they did the job again. Two days later they called and asked about the seal. Still leaking so its going back to them as the job is under warranty. I'm just trying to understand the problem. I have not heard of a speedi sleeve. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Larry, It looks like you are referring to a leak at the front (forward side) of the drive pinion (not a leak at an axle seal)? Are the 55-1st parts similar to 1955-2nd parts? The problems might be (I have had all three problems on a similar GMC pinion seal): - wrong size seal (#21 companion flange oil seal) - wrong companion flange (#23) - groove in the seal mating surface on the companion flange (#22) Dave and Wrenchbender: is the companion flange called a (rear) u-joint yoke? If there is a repair sleeve available for the companion flange? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1955 first uses the same parts as 55 second. Yes #22 in your link, "companion flange", if the same thing as a yoke.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | As shown in Tim's link, it is the #22 seal. Seams like such a simple fix. I would do it myself but already paid the shop to fix the problem. Its hard to believe the shop replaced the seal twice and it still leaks. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Is the shop experienced with these early differentials that use a crush sleeve between the pinion bearings?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2008 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 239 | Just got the truck back from the shop. The problem is finally fixed. New pinion seal, carrier gasket, cover gasket and axle seals. Lots of excuses from the shop. No additional charges. | | | | | Joined: Jul 2013 Posts: 47 1949 Beast | | 1949 Beast Joined: Jul 2013 Posts: 47 | Be sure to check that the axle housing is venting properly, too. There is a vent, that when plugged with dirt or whatever, would allow pressure to build up and push fluid out of the weakest seal. | | | | | Joined: Mar 2011 Posts: 277 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 277 | I wanted to ad to this post that the speedi-sleeve and pinion seal part number for a 1955 first series are:
Speedi-sleeve 99170 Pinion seal 17727
These are both made by SKF
I got these from NAPA and they worked perfectly
Joe
1955 First Series 3100
