Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#976857 10/06/2013 6:46 PM
Online I've seen some Engine Intake Rings, which are suppost to prevent manifold leaks. I have a 52 Chevy 216 engine; can someone tell me if these rings really work? Thanks.
The rings help for alignment when installing the manifold
I guess in that way the can help in preventing leaks,
they can also cause a leak if cocked a little when installed,
or as I found out in a step ring I used
was made to thick and caused a leak
Best method I found to stop a leak was to take my manifold to a machinist to deck it, then torque the assembly in sequence using the torque specs in the manual. Torquing the manifold and heat box in steps.
DADS50 #976996 10/07/2013 7:28 AM
1 Offline
The rings are essential for aligning the intake ports in the head and intake manifold. The port mounting flange on the manifold is narrow enough, that it can mis-align easily and not seal to the head if you leave them out. Don't try to out think the GM engineers that designed them, they serve a necessary purpose.
We cannot solve our problems today using the same thinking we used when we created them!
Albert Einstein
