0 members (), 108 guests, and 2 robots.
Topics128,035
Posts1,055,560
#976944 10/07/2013 1:05 AM
The hoses on my 38 half ton are pretty sketchy looking, so I bought a hose kit. Now that I'm ready to replace them, I'm not sure on the best way to replace the upper hose (from the thermostat housing to the radiator).
The hose is a straight hose and pretty short. It seems the only way to remove it is to lift the radiator. Seems like a lot of work to replace a hose.
Any suggestions on how best to replace the hose? I'm worried about damaging the radiator/upper fitting if I try to strong-arm it too much.
I should add that this truck is currently a weekend driver, so I was hoping to avoid any major disassembly.
Thanks for your thoughts.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Hoff #976959 10/07/2013 2:09 AM
First off, cut the old one off, its probably stiff from age. Soak the new hose in really hot water to soften it up. Bend it in the middle and in one quick move shove it on both fittings at once. A little lubricant won't hurt.
Joe
Hoff #976978 10/07/2013 3:36 AM
Joe's method works great.
If you are taking this chance to change the thermostat, while the you have the top casting off, put it into the top hose then bolt it back on. No bending and pushing.
Hoff #976999 10/07/2013 8:08 AM
I changed my 38 hoses basically as they suggest above. I used a reinforced spiral hose for my lower like the ALLSTAR brand that summitracing carries. That was a direct replacement to what was on there previously. It went on fairly easy with a little elbo grease.
I like it enough to change the top hose to the same.
Good luck with your project.
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
Hoff #977021 10/07/2013 2:11 PM
Ex Hall Monitor
Ex Hall Monitor
The inlet at the top of the radiator is quite a bit longer than necessary. On my coupe I cut the hose to the length where when I shove it all the way up on the inlet, it just clears the thermostat housing outlet then slide it down into position and tighten the clamps. Easy peasy.
Hoff #977066 10/07/2013 6:07 PM
Thanks guys. Appreciate the advice. I'll put a new thermostat in while I'm at it. Not sure what shape the old one is in.
I'm just doing minor maintenance things at this point, and trying to get the truck into a relatively reliable toy. I don't venture too far in it yet, not until I have a little more confidence in it.
The main thing now is to get the hoses replaced and get some new anti-freeze in it. Winter's coming!!
Thanks again.
1938 Chevy 1/2-ton
Hoff #978867 10/15/2013 7:41 PM
You are right to be careful of the radiator top inlet. I thought I was being gentle and still caused a leak where the tank meets the core.
