2 members (3B, 1955 1 Series),
36
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Online I've seen some Engine Intake Rings, which are suppost to prevent manifold leaks. I have a 52 Chevy 216 engine; can someone tell me if these rings really work? Thanks. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The rings help for alignment when installing the manifold
I guess in that way the can help in preventing leaks, they can also cause a leak if cocked a little when installed,
or as I found out in a step ring I used was made to thick and caused a leak
Best method I found to stop a leak was to take my manifold to a machinist to deck it, then torque the assembly in sequence using the torque specs in the manual. Torquing the manifold and heat box in steps.
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | The rings are essential for aligning the intake ports in the head and intake manifold. The port mounting flange on the manifold is narrow enough, that it can mis-align easily and not seal to the head if you leave them out. Don't try to out think the GM engineers that designed them, they serve a necessary purpose.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
