5 members (frogfarmer, baldeagle, Otto Skorzeny, tclederman, Rusty Heaps), 62 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#976580 10/05/2013 1:25 AM
So after about a million searches I decided to try, the Tech Tips section. Cool! I have an AC Delco S-2 filter. The big one. That is why the filters that my friends keep telling me to use just floats around in the big deep hole. Thanks to Pat Doonan I have the part number I need. Thanks to all who help on this site. FYI the filter is Fram C31PL available at the local FLAPS. Makes you wanna smile.
Steve H
Steve_H #976604 10/05/2013 8:49 AM
Good searching, Steve.
Thanks for posting a brand/part-number.
Steve_H #976634 10/05/2013 11:04 AM
Yeah Steve, tks, that filter was not all that common back in
the day so you can imagine how seldom it's seen now days. I'm
even surprised that you can still get an element that fits that tall canister.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Steve_H #976676 10/05/2013 4:03 PM
Found the filter at Autozone. The filter case has a drain on the bottom that and a bit of hose makes the messy part of the oil change so much less messy. Mine has a brass valve that works just fine. So I wanted to keep it and be able to use it. And the extra oil it holds hurts nothing. Better than trying to get a quart of oil out with rags and a can. Just drain and go.
Steve H
Steve_H #976681 10/05/2013 4:21 PM
Question. When changing the oil on one of these 216/235 with an oil filter. Do you fill the oil canister separately when you fill the engine? Add extra oil to the engine when you fill it?
Steve_H #976683 10/05/2013 4:28 PM
I just put 5 quarts in the engine and run for about 5 minutes. Then I put in 2 more quarts and check the level on the dip stick. Seems to be OK. The 5 minute run lets the canister fill and I don't have to mess with the filter after I have cleaned it all up. If you don't get the lid on just right it will leak like crazy. So when that lid is on I like to leave it alone. Hope this helps.
Steve H
Steve_H #976689 10/05/2013 4:37 PM
It depends on how/where you oil filter canister returns oil to the block. Some empty at the bottom of the canister and some empty higher up the canister.
My by-pass canisters empty higher up the canister.
After removing the filter, sucking out the oil, and putting in the new filter:
- Fill the engine with specified amount of oil (5 qts).
- Fill the 1-qt oil canister with a 1-qt of oil (fill the 2-qt canister with 2 qts of oil).
- Start and run the truck for several minutes.
- Turn off the engine, clean up, and have a home-made beer.
- Check the oil level, and top up as necessary.
Steve_H #976721 10/05/2013 8:02 PM
I believe mine has one line off the bottom and one comes off the side of the canister. For some reason I'm tyhink C-21 filter, but I may be wrong. I have the oil ports plugged right now on the engine.
