Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 49 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#976660 10/05/2013 2:26 PM
Just bought a 51 3100 w/ a 235. It seems to be OK, but I was wondering if a 250 would be an easy drop in. I'm just checking my options. This truck will have to earn its keep, and I like the simplicity of the old straight sixes. I'll probably drive yall crazy once I get this truck home tomorrow, so please be patient. John
tinnerjohn #976668 10/05/2013 3:25 PM
Riding in the Passing Lane
It is not an easy drop in. It takes quite a bit of modification. I do like the 250 though. It takes a lot of weight off the front end. It is a good strong dependable engine. If the 235 is good I would leave it alone. If you need a replacement then consider a 250.
1972 Chevy c10 Cheyenne Super
tinnerjohn #976760 10/05/2013 10:14 PM
Thanks. I plan to keep the 235, but I was just thinking about options, since I plan to keep this truck and I thought a 250 might be easier/cheaper to find to rebuild if that becomes necessary. I may just watch for a 235 to put on the shelf. Naturally, I'll have a way better idea of whats needed when I get this truck home, but right now I'm like a 3year old waiting for Santa!
tinnerjohn #976955 10/07/2013 2:00 AM
Gas Pumper
Gas Pumper
The 235 has really stood the test of time. So keep your 235 and then put a 261 on the shelf. Same footprint, almost same engine, with just a bit more horsepower and no problems. These engines last forever. Was the 250 known for the same longevity? I don't know.?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
tinnerjohn #977039 10/07/2013 4:34 PM
Like the others said....the 235 is rock solid. If you want a few more cube's you could have the 235 bored larger then you won't have to do alot of work to fit a 250 in it. Or find a 261.
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
tinnerjohn #977045 10/07/2013 4:49 PM
I love 235's but a 250 is a much better engine in my opinion, with seven main bearings and individual rocker pivots.
That said, it is way too much work to mount one in a 51 PU.
My Blog
