| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Just bought a 51 3100 w/ a 235. It seems to be OK, but I was wondering if a 250 would be an easy drop in. I'm just checking my options. This truck will have to earn its keep, and I like the simplicity of the old straight sixes. I'll probably drive yall crazy once I get this truck home tomorrow, so please be patient. John | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It is not an easy drop in. It takes quite a bit of modification. I do like the 250 though. It takes a lot of weight off the front end. It is a good strong dependable engine. If the 235 is good I would leave it alone. If you need a replacement then consider a 250. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Thanks. I plan to keep the 235, but I was just thinking about options, since I plan to keep this truck and I thought a 250 might be easier/cheaper to find to rebuild if that becomes necessary. I may just watch for a 235 to put on the shelf. Naturally, I'll have a way better idea of whats needed when I get this truck home, but right now I'm like a 3year old waiting for Santa! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The 235 has really stood the test of time. So keep your 235 and then put a 261 on the shelf. Same footprint, almost same engine, with just a bit more horsepower and no problems. These engines last forever. Was the 250 known for the same longevity? I don't know.? | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 | Like the others said....the 235 is rock solid. If you want a few more cube's you could have the 235 bored larger then you won't have to do alot of work to fit a 250 in it. Or find a 261.
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I love 235's but a 250 is a much better engine in my opinion, with seven main bearings and individual rocker pivots. That said, it is way too much work to mount one in a 51 PU.
See the USA in your vintage Chevrolet! My Blog | | |
