3 members (David Bush, Peggy M, 1 invisible),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 20 New Guy | | New Guy Joined: Sep 2013 Posts: 20 | I have a 1946 Chevy 2 ton that has a vacuum brake assist and I don't know how to tell if its working or how to repair it if it isn't... Anyone know how I can check or fix this? | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | put your foot on the brake pedal then start truck. if brake pedal drops slightly then most likely its working. disconnect the steel vacuum line from the unit(line coming from engine) if you get brake fluid running out then some of the seals are leaking and the unit is on borrowed time. if you havent post a pic of the unit. | | | | | Joined: Sep 2013 Posts: 20 New Guy | | New Guy Joined: Sep 2013 Posts: 20 | Ok, thats what it does. Thanks for the help nice to know its still working! | | |
