0 members (), 139 guests, and 1 robot.
Topics128,127
Posts1,056,680
Members48,452
#976390 10/04/2013 12:32 AM
I have a 1946 Chevy 2 ton that has a vacuum brake assist and I don't know how to tell if its working or how to repair it if it isn't... Anyone know how I can check or fix this?
1946 Chevy 1/2 Ton
More pix on Photobucket
1946 Chevy 2 Ton
"if it ain't rattlin' it aint broken"
put your foot on the brake pedal then start truck. if brake pedal drops slightly then most likely its working. disconnect the steel vacuum line from the unit(line coming from engine) if you get brake fluid running out then some of the seals are leaking and the unit is on borrowed time. if you havent post a pic of the unit.
Ok, thats what it does. Thanks for the help nice to know its still working!
1946 Chevy 1/2 Ton
1946 Chevy 2 Ton
