0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I just went and looked at a 48 GMC 1 ton and the grille sticks out a LOT more than my 53 grille. Mine is basically flush with the surround piece but this one pictured here sticks out 6-8 inches. Did the grilles change sometime between 48 and 53? The truck looks to be all original so I don't think there has been any "engineering" going on. | | | | | Joined: Aug 2006 Posts: 129 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 129 | Yes, they changed. The early versions used the big truck grille that was mounted to the frame. The later versions used a different small truck grille that was mounted to the sheetmetal. I can't remember the exact year break...I think the late '47-49 and then '50 and later. I'm sure someone else will chime in with an exact year. | | | | | Joined: Sep 2001 Posts: 168 'Bolter | | 'Bolter Joined: Sep 2001 Posts: 168 | 47 and 48 use the 3 bar grille with the much more pronounced uprights, as well as a completely different front bumper. 49-55.1 are all the same grille and share the front bumper with 47-55.1 chevy trucks. This is for 1/2 through 1 ton trucks of course.
1956 GMC 100 NAPCO Deluxe 1955.1 Chevy 3600 NAPCO 1954 Chevy 3600 NAPCO
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Thanks, I think i'm gonna buy that truck and do a stock restore. It was originally red. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Checked the "VIN" which is the motor number against the title from Nebraska. I will have to have it verified with the state patrol.
B228I80815 on the motor.
B228180815 on the title.
Obvious typo, but what are the chances that it will give me problems?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | both those numbers are the same, as long as the 'ell' on the engine looks anything like the one
Bill | | |
