| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | On my '46 half ton, there are two control knobs above the driver for the wiper (drive side only in my case). At times, if I pull and twist and move these knobs, the vacuum wipers will move. Exactly how are these knobs supposed to work? I referred to the owner's manual and service manual and found nothing. Are the knobs to be pulled? Turned? Is one 'on and off' and the other 'speed control'? Which one is which? Left? Right? Any help is greatly appreciated.
Also, any recommendations on a good 'replacement arm and blade' are appreciated as the ones I ordered (company name omitted) are very thin and leave a lot to be desired. Thanks!
| | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | The one that you can pull and push in is on / off pull = on push = off, you turn the speed control clockwise to slow the motor down. Most vendors that carry replacement carry only original style arms and blades. Original style blades are thin, there were replacements that were of more modern style to use them you would have to add a adapter to the shaft to use the new style arm. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | Thanks OLTrucks! If anyone has changed up their blades with an adaptor, I'd like to hear about it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Todd - check a marine supply store for blades that fit on the original arms but work much better, boats use similar
Bill | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | Hope to see body (not fender) color restored to strip between the two grille sections, some day | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I've fought wiper blades with my 46 also, now have taken them off until I find a better set up. Don't forget to use LOTS of RAIN-X. Saw a youtube on applying it, use copious amounts rinse and repeat! | | |
